anyone install a rack and pinion on stock subframe??
Old Nov 28, 2016 | 10:32 AM
irocturn&burn's Avatar
Car: 91 Z28
Engine: aluminum block 5.3
Axle/Gears: 4th gen rear 4:10 welded
hello, i was curious if anyone has managed to affix a rack of some sort on a stock subframe. I know most people are gonna say buy a tubular k member, i would love to, but I will be entering this car into 2017 pro-am drift series and rules state vehicle must use the stock subframe. steering modifications are free though. so before i start welding and cutting, i was seeing what anyone else did, my goal is lighter front end weight with a rack over an iron box, and to gain some more tie rod travel for turing angle. Thanks!!
Old Nov 29, 2016 | 08:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: anyone install a rack and pinion on stock subframe??
I don't feel the actual weight savings is worth the effort. Shorten the steering arms on the factory knuckles and your done. There is more weight to be saved with a lightweight hood and front impact bar.
Old Dec 4, 2016 | 12:29 PM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
I looked at this pretty extensively but couldn't find a way to make it work. You need a very narrow rack to avoid excessive bump steer. If you can find a rack that will work (most likely a custom rack since most stock units are too wide), the input shaft is probably going to be too far inboard to make the steering column work without a number of u-joints.
I'm not saying it's impossible, but a number of people have looked into it and I'm unaware of anyone that was really successful. I hope you're able to make it work, I'd like to see this done.
