Lets see your Road Race / Autocross Suspensions!
Old Feb 13, 2017 | 09:35 AM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
Post em! Pics or they don't exist!
Old Feb 14, 2017 | 12:55 PM
Beater79TA's Avatar
Re: Lets see your Road Race / Autocross Suspensions!
Build info is located here for the GTA: https://www.facebook.com/DragonladyGta/
Front suspension is:
Ground Control Weight Jacks with 950lb springs
UMI/Afco double adjustable roadrace / autocross valved front struts
1LE 36mm front sway bar
TopDown Solutions wonder bar
UMI caster camber plates
BMR tubular LS swap k member and front A arms
Rear suspension:
12 bolt Moser axle
UMI adjustable rotojoint lower control arms
UMI adjustable rotojoint panhard bar
UMI adjustable transmission mount torque arm
UMI adjustable rear coilovers with 400lb springs valved for roadrace/autocross use
1LE 24mm rear sway bar
Wheels are Forgeline 18x10.5 with 315/30/18 BFG Rival S tires
Car also has Alston inner SFCs and a custom chromoly cage.
Old Mar 24, 2017 | 10:47 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
Front: custom made chromoly custom width a-arms with adjustable heims
Custom made one off coilover s with PAC 275lb springs and internal resivours and zero preload
Valves for road racing, hotchkis swaybar with heim joint end links, hotchkis strut tower brace which is being replaced with a custom one off piece. Custom made tie rods with heims
Iroc steering box, custom made upper strut mount camber plates made with 7/8 unibal bearings. Also using 2in spacers for the z06 wheels
Rear- matching rear shocks with remote resi mounted through the body to the cage. Hotchkis rear swaybar and adjustable pan hard bar, boxed lower trailing arms and modified stock torque arm, custom PAC racing springs, 4th gen rear end 1.5 inch spacers
Old Mar 28, 2017 | 09:27 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
Morrow, what customizations did you make to your A Arms?
Old Mar 30, 2017 | 10:07 AM
morrow's Avatar
Car: 92 Camaro Rs.R
They are chromoly tubular a arms built to be 3inches or so.. wider then stock on each side
