Warped crossmember?
Old Jul 9, 2017 | 11:29 AM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Warped crossmember?
All;
I replaced my torque arm bushing with an Energy Suspension urethane bushing, and intended at the same time to replace the hydraulic mount crossmember with the solid...
It turned out that the crossmember was severely warped, even with the T-5 jacked up to the floor of the car, there was no room. (Forklift damage at the yard)
Yesterday, I found a crossmember lying in the back of a Camaro...but noticed when it's lying on a flat surface, one end lies flat, and the opposite end is at a slight angle. It this crossmember bent? Pic to follow soon.
Old Jul 9, 2017 | 01:18 PM
Re: Warped crossmember?
One side of the "frame" where it bolts to, is parallel to the ground; the other is at an angle. Maybe 15 - 20°.
Old Jul 9, 2017 | 03:35 PM
Car: 1988 IROC-Z
Like this? The opposite end is lying flat on the concrete.
I just want to be sure that it's good before tearing the car apart again.
Old Jul 9, 2017 | 07:44 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
That's normal. You'll see when you go to bolt it on that it's OK.
Old Jul 10, 2017 | 08:01 AM
I agree, that looks about right. Should be OK.
Old Jul 10, 2017 | 05:13 PM
Car: 1988 IROC-Z
Thanks, guys! I'll probably put it on this weekend. Should be a good bit more solid than the hydraulic mount.
Old Aug 4, 2017 | 06:02 PM
Car: 1988 IROC-Z
Thanks, all for the sanity check. The crossmember was perfect, and I had no issues at all. Eliminating the failing hydraulic transmission mount made a noticeable difference.
