Maxed out camber caster plates
Old Jul 31, 2017 | 05:11 PM
McLovin1181's Avatar
I got a set of J & M caster camber plates
but I can't manage to get the correct alignment
(I'm using a camber caster gauge)
I MAXED the caster and camber settings and was only able to get 4 degrees caster and Zero camber.
the original mounts were able to get an alignment at a shop no problem.
What am I doing wrong?
Old Jul 31, 2017 | 06:05 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: Maxed out camber caster plates
Check where the street mounts to the spindle... Other things to check are a arm bushing and of course bent parts...
Old Jul 31, 2017 | 06:33 PM
I checked the Strut bolts, and they are tight.(120lbft +30 degrees)
A-arm bushings have about 200 miles on them and arn't cracked or broken.
well, guess I'm in for some fun.
Old Jul 31, 2017 | 08:30 PM
daferris's Avatar
Are you sure your caster camber gage is accurate? how about putting the gage on another car to see what it reads?
Old Jul 31, 2017 | 09:03 PM
That's a good idea.
My brother has a Corolla in storage I can test it on.
Old Aug 2, 2017 | 04:08 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
don't know if this will help. Mine are like this
