Suspension jingle
Old Oct 21, 2017 | 07:29 PM
Ragin's Avatar
Car: 1989 IROC-Z
Engine: 305ci TPI
Suspension jingle
I have a jingle in my front driver's side wheel well and many people (on this website included) have said that it is the sway bar link. I changed out the link earlier today with a Moog replacement link (I about laughed the guy behind the counter out of the building when he opened the box in front of me and the contents were a bolt, a sleeve, four washers, four bushings, and a nut). Once the new link was installed I took the car for a test drive and the jingle was still there.
Any ideas????
Thanks!
Old Oct 21, 2017 | 10:05 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Suspension jingle
What car do you have? There's lots of parts on the drivers side of the car. Vacuum ball, 2 horns, charcoal canister, washer fluid tank, also it could be the upper strut mount( the bearing the strut mounts to blow out and or the rubber in it). You will need to start to track it down.
Old Oct 22, 2017 | 05:47 AM
Ragin's Avatar
Car: 1989 IROC-Z
Engine: 305ci TPI
1989 IROC Z 305TPI
