Alternative shocks and struts
Old Oct 29, 2017 | 10:18 AM
faisal's Avatar
Hay guys , I have this 89 GTA got it from previous owner and shocks are not comfortable at all that some interior accessories start cracking while driving , would the fourth gen shocks fit , and if not , is there any other GM ride has the same shock to be alternatively used ..
Thanx ..
Old Oct 29, 2017 | 10:46 AM
Re: Alternative shocks and struts
Rear shocks yes. They are the same, part # for part #.
Front shocks no. Our cars use struts up front.
Old Oct 29, 2017 | 11:03 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
There are more than 1 set of shocks/struts made for the third gen... KYB has 2 lines of struts for up front, and 3 types of shocks for the rear. Koni makes some, Monroe makes some...
When you get down to it, these are sports cars. You will not have a floaty boaty ride. If you want that, you want another car.
Old Oct 29, 2017 | 11:28 AM
faisal's Avatar
I know broo , sure these cars are sporty, I have another 91 T/A and it has a really smoothly driving ..
I used have 92 like 4 years ago and was a Gabriel on it , I will be appreciated if any would help me with the part number of it
Old Oct 29, 2017 | 12:31 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You want to buy an OE quality shock. Any change from OE will be for improved handling and make the ride harsher. Two other things you may look into are springs and subframe connectors. If the springs are original then they are sagging and soft possibly limiting the travel of the shock and making for a more harsh ride. Subframe connectors may be a shot in the dark. They stiffen the chassis and give the added benefit that when you go over bumps the body itself doesn't flex and thus introduce more creaks. Everybody who owns a thirdgen and takes pride/enjoyment from it should put subframe connectors on the car.
Old Oct 30, 2017 | 10:51 AM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Also new suspension might help “dampen” those interior rattles but they will not diminish them completely.
Your gonna have to tighten everything that you can inside and use 3m foam tape (or something similar) in the small loose crevices that creak.
