Adjusted steering gear & New Rag Joint: Car pulls to the right
Old Dec 6, 2017 | 04:20 AM
F-body driver's Avatar
Car: 1987 Trans AM WS6
Transmission: TH700R4 Stock
Axle/Gears: 3.08 LSD
Hello Guys
I've recently put new rag joint and adjusted my steering gear but the steering wheel is not centered!
If I let it straight the car pulls to the right
Could I have messed the steering gear by tightening the preload nut?
Old Dec 6, 2017 | 06:47 AM
Re: Adjusted steering gear & New Rag Joint: Car pulls to the right
Maybe but probably not.
Try exchanging the 2 front tires. See if it changes.
Old Dec 9, 2017 | 07:43 AM
Ok I'll try for sure!
If tires are not the problem what could it be?
The car has been aligned 3k miles ago with all new suspension parts
Old Dec 9, 2017 | 08:08 AM
Alignment
"Been aligned" != is FOR SURE aligned correctly
