ws6 box play
Old Jun 10, 2018 | 07:28 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
ws6 box play
How much play is normal in a ws6 box?
I had an alignment done, then a week later I bought new sticky directional tires.
Now, going down the road the car will wander in one direction, left or right. When I correct it, it will start wandering the other way, and so on. I've got almost 60 degrees of play in the steering wheel.
I don't have a rag joint, I have a astro shaft. The play is in the box.
-- Joe
Old Jun 10, 2018 | 07:47 PM
Drew's Avatar
Re: ws6 box play
I would expect sloppy steering to be sloppy everywhere. Like a Chrysler Cordoba. Wandering sounds more like an alignment problem.
Old Jun 10, 2018 | 07:57 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: ws6 box play
Everything is new, other than the box, and I just had it aligned at a good shop.
Old Jun 11, 2018 | 06:14 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: ws6 box play
Normal compared to what? Brand new or most of the shitboxes rolling around still? There should be no play in a box, mine with 70k miles has zero play in it at all. Rebuild it yourself if it's a quick ratio box, it's easy. Most re-manufactured from auto parts stores are not, even if they say they are. I've heard a lot of horror stories about the expensive boxes from "high end" brands too.
Old Jun 11, 2018 | 07:04 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: ws6 box play
So I tightened the backlash as much a possible, and it's still got a ton of slop in it. The pitman arm doesn't even think about moving.
Old Jun 17, 2018 | 07:12 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: ws6 box play
Swapped the box and its all set.i checked the other one on the bench, I think the gears are chipped or something. It turns a significant amount before the pitman arm moves.
-- Joe
gmgod
Aug 2, 2002 10:48 AM
RSpeed
Feb 1, 2001 09:35 AM
