Question for Steve Spohn
Old Jan 8, 2002 | 02:54 PM
Momar's Avatar
I am planning on buying a set of your subframe connectors and also am planing on Hooker Long Tube headers sometime in the future. I was wondering if these would clear your subframe conectors. If possible I want to run true duals when I do this. If you do have subframe connectors that will allow this do I just need the standard ones or one of your special ones. True duals is not totaly nescesary but I want a good flowing exhaust and need to be able to fit something that flows good whether it be duals or large single pipe(preferably duals). Oh, by the way it is an 85 trans am. Previously lg4 but currently recieving a 350. It does not have the air pump or the associated lines or cat. Oh, by the way has anyone else ran true duals or these headers with Spohn connectors? If so I would like to know if you had any dificulties or not.
Thanks for your help,
Ben
Old Jan 8, 2002 | 05:58 PM
SteveSpohn's Avatar
The Hookers will clear the std. single cat SFCs just fine. I have 4" true duals under my car, no problems with the SFCs.
Steve
Old Jan 8, 2002 | 07:42 PM
Momar's Avatar
That i awsome. It will probably be a while before I order them but I will probably order some within the next month or two.
Ben
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
ydnar417
Sep 23, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
