Torque arm relocation bracket
Old Jan 25, 2019 | 08:57 PM
odin65's Avatar
I have an 88 IROC 5.7 700r4, i have tried the UMI 2228 and the BMR TCC017 and both move the trans up. The UMI pushes it up 1/2 inch and the BMR pushes it up a heavy 5/8 inch, has anyone used either one and experienced the same? Thanks
Old Jan 26, 2019 | 05:53 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Torque arm relocation bracket
What transmission mount are you using
Old Jan 26, 2019 | 09:20 AM
odin65's Avatar
I am using an energy suspension poly bushing to replace a 20 year old es poly that actually measures the same height as the new one with both using the preload plates. I also went to autozone and bought a new rubber one that is virtually the same height. When i put a straight edge across the center of the bolt holes and measure the pad height, the factory is 5/8 heavy space, the umi is 1/8, and the bmr pad is actually higher than the straight edge. When i sit the tranny down on these the universal is instantly in an awkward position. I tried searching the forum to see if anyone else had this issue and didnt see any. Thanks
Old Jan 26, 2019 | 09:33 PM
odin65's Avatar
I just found the energy suspension 3.1158g short trans mount, its 3/8 shorter than stock. Has anybody used it? Thanks
Old Jan 27, 2019 | 05:08 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I have the other style UMI trans crossmember with drive shaft loop, I use a prothane mount. Alot of people have problems with the energy sus. and the preload plate
https://www.summitracing.com/parts/p...t/model/camaro
armybyrd
Mar 9, 2016 10:11 AM
Justin69
May 10, 2015 09:45 PM
QwkTrip
Feb 16, 2011 10:51 PM
tpi_roc
Dec 12, 2001 11:58 AM
