Lakeland LCA's
Old Jan 9, 2002 | 10:37 PM
dtpmike's Avatar
Lakeland LCA's
I just installed them. I tightened the bolts up as much as I could when the car was in the air, but I never did when the car was planted, will this matter?
Also the grease fitting is broken on one side. It leaks out of the hole slowly. Im sure there is some grease still in there, but not as much as the others and it does not really hold it good. Should I fix this?
Old Jan 10, 2002 | 08:09 AM
dtpmike's Avatar
ttt
Old Jan 11, 2002 | 10:58 AM
dtpmike's Avatar
How come no one will help me?
Old Jan 11, 2002 | 10:36 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
You should have torqued them to spec while the car was down on the ground or a jack under the pumpkin. I wouldnt worry about the greese fitting. I remember Hotckis recommending 100FT lbs to torque them too.
Jorlain
Oct 8, 2015 01:57 AM
Americanmouse
Sep 7, 2015 12:10 PM
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
NBrehm
Aug 5, 2015 07:57 PM
