Outter Tie Rod
Outter Tie Rod
Will these work? I'm looking to replace my Tie rod, Outter ones most importantly. Thanks
Anyone have pictures?
Tie Rod Sleeves for GM
For a positive steering improvement from your Camaro/Firebird, A/G-Body, install these heavy-duty Edelbrock Tie Rod Sleeves. Made of 7/8" diameter D.O.M. steel tubing and .156" walls, they have ground wrench flats for easy adjustment and come with steel jamnuts. For 1967-69 & 1982-92 Camaro/Firebird, 1978-88 A/G-Body and 1964-70 A-Body with 5/8" tie rod ends.
GM Tie Rod Sleeves for Camaro/Firebird, A/G-Body with 5/8" tie rod #5203
Car: 1985 Trans Am
Axle/Gears: 3.70
They'll work on your vehicle, but just so there is no confusion these are the adjusters - not the tie rods themselves. They connect the inner to the outer tie rod.
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
Re: Outter Tie Rod
Rob
Car: 82 camaro SC
Call around to some local parts shops, I'm sure somebody carries Moog. Tie-rods will last a long, long time if they are greased properly. You won't notice a difference in brands. Idler arms are a different story, buy the good ones because they wear out frequently.
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
