rear end from junkyard??
Old Jan 20, 2002 | 09:00 AM
87firebird's Avatar
If I go to a junkyard and find a posi rear end w/ around 3.23 gears, how much do you think it would cost and would it last?? Or is there a way I would be able to rebuild it and make it last longer and perform better?? Is it worth it, or should a get a new one?? thanks
Old Jan 20, 2002 | 10:32 AM
ede's Avatar
ede
if you're after a posi carrier best thing to do would be to buy a SLP and put it in your rear. they're for 28 spline only so make sure what you have. to answer your question there shouldn't be a problem getting a used one, i'd take the cover off take a look around, change the oil and additive, maybe seals and run it.
Old Jan 20, 2002 | 11:08 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I would look for a '89-'92 with disc brakes rear.
Old Jan 20, 2002 | 06:41 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Go to www.car-part.com and follow the prompts. This will give you and idea of what scrap yards are charging for rears in your area...works pretty well. You can find almost anything you want.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
