UMI Torque Arm Hitting Speedo Sensor
Old Oct 3, 2022 | 11:05 AM
Gabagool984's Avatar
Car: 89 Camaro RS
Engine: 383 Stroker
Transmission: 700R4 Streetfighter
Axle/Gears: Hawks 8.8 - 3.73 Posi
Hey all.
So i have the UMI torque arm relocation bracket and adjustable torque arm. The problem I’m having now is that the torque arm is hitting the speedo sensor on the 700r4. Has anyone experienced this or remedied it? Pic attached
Old Oct 8, 2022 | 03:48 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Re: UMI Torque Arm Hitting Speedo Sensor
i don't have direct experience with this torque arm with 700r4, but i have had to shorten this torque arm to avoid similar problem on t56 swaps. i cut the end off and weld a plug in the end
Old Oct 18, 2022 | 09:00 PM
Beater79TA's Avatar
Same. Cut an inch off the front with our T56 swap to keep it clear of the speed sensor. As long as it goes through the bushing you won't have an issue.
Old Oct 18, 2022 | 09:07 PM
Car: 89 Camaro RS
Engine: 383 Stroker
Thanks, yeah I found the issue with mine. I’m running a new hawks 8.8 rear and the size of the rear of it moves the torque arm up further. Cut an inch off like you guys said and all it good
BADMAN
South Central Region
Nov 17, 2008 06:35 PM
JamesC
Jan 12, 2002 11:19 PM
