violent side to side movement,,please read
Old Jan 20, 2002 | 08:42 PM
sslee's Avatar
I took my car down the road today for the first time after building it. I have regular radials on the back for now. It also has an auburn posi in it.
1rst gear was useless,,spin ,spin spin
2nd gear had a violent side to side movement untill I let off and got back in it again, it was spinning while it was doing this.
The best way to describe this is to say that someone was at the back side of the car and was shakin it as hard as they could from side to side..
What the hell is doing this? It did it 3 times!!!!!
Old Jan 20, 2002 | 11:09 PM
sslee's Avatar
help me????
Could it be the lca flexing and stock bushings??
Old Jan 20, 2002 | 11:53 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
It could be a lot of things. I would say it is most probably the motor or transmission mounts. It could also be that the drive shaft is way out of wack. Meaning that the driveshaft is not balanced or is bent.
Old Jan 20, 2002 | 11:57 PM
sslee's Avatar
new motor and transmission mounts,
only does this under hard acceleration, no other time
Old Jan 21, 2002 | 08:45 PM
sslee's Avatar
surely someone else had this problem before????
Old Jan 22, 2002 | 11:30 PM
sslee's Avatar
back up top..
Old Jan 22, 2002 | 11:59 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
It could be that there is something wrong with your torque arm, is damaged, missing or modified. Mine used to do this on my th350 tranny in my 1982 Z-28. But it was not violent and only occured when i was coasting, engine braking in second going 20 mph. I fixed it by building braces that loosely bolted from the body to the torque arm.
Old Jan 23, 2002 | 10:11 AM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Go to the back tires of your and push on the quarter pannel. Does the car body move side to side while the tires stay in place? Mine had this problem, I replaced the LCA's, panhard, and rear sway bar bushing with poly parts, and no more problem.
Old Jan 23, 2002 | 04:12 PM
sslee's Avatar
no, the axle moves with the body.. there is some tire flex but that's it..
Old Jan 23, 2002 | 06:01 PM
sslee's Avatar
it has sfc too!!!!!!
Old Jan 24, 2002 | 12:17 AM
AntiVTEC's Avatar
Might be kinda off but what about your diff? Is it working properly and locking both tires together? might be jacked up and is alternating power left and right....
Old Jan 24, 2002 | 07:22 AM
82camaro's Avatar
Car: 82 camaro SC
Could be wheel hop, mine used to on the 1-2 shift.
Old Jan 24, 2002 | 08:34 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
My car used to do that, when it had a 400 in it... LCA relocation brackets and LCAs finally fixed it. The car had SFCs and a Spohn torque arm, neither of which affected it much. It was so bad that people would ask me if I was doing it myself with the steering wheel. I could hold the wheel still & stand on the gas, and feel the rear end swinging itself from side to side. It did it both with a on-wheel-peel and a posi.
Mutillator
Exterior Parts for Sale
Oct 1, 2015 06:05 PM
mizz0313
Aug 12, 2015 06:45 AM
BlackBoulder
Aug 11, 2015 11:15 PM
novaderrik
Aug 10, 2015 12:44 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
