need suspension help
Old Jan 21, 2002 | 09:48 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
ok guys
my car is fugged up
here's what wrong:
when i turn the wheel ALL the way to the left and drive (as in pulling out of a parking spot) i hear a REALLY loud clunking noise
and my steering wheel is cocked to the right when i am driving in a straight line..................
i am running 1991 Z28 wheels...........so i dont think tires hitting is my problem
someone told me it sounds like my tie-rods
i want to know what to look for, what performance parts to add and what to rebuild...................i have suspension class this semester and want to rebuild my front suspension for performance........... maybe even add some drop spindles in the front
what are some good performance parts to add?
Old Jan 21, 2002 | 01:14 PM
MR KEITH's Avatar
I had a lot of noise coming from my front end.I bought a kit from p-s-t,it's a polygraphite set up.Its only $159 and comes with every ting but inner tie rods $35 ea.and a center link $45.It was the best $275 up grade I've ever made.Drives like new.I also went with new v8 springs,struts,and rear sway bar poly kit.I also found 2 bad tie rods and centerlink when removed
Old Jan 21, 2002 | 09:20 PM
cool thanx
i'll definetly look into this
i guess also maybe larger sway bars???
i also want to put on drop spindles in the front
Old Jan 23, 2002 | 01:29 PM
89 CamaroIROCZ's Avatar
Can you explain further this p-s-t upgrade?
Matt
Old Jan 23, 2002 | 01:39 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Could be the same problem I was having with mine. It would also make a clunking sound when turned all the way to either side.
Your problem may be with the steering stops. Put some grease on the part of the spindle that makes contact with the steering stop on the control arm. Did it on mine and solved the problem.
Let me know if this works
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
