Some spohn questions
Subscribe
Jan 21, 2002 | 10:00 PM
Hey come spring and my Camaro is out again im lookin at getting some suspension mods so i don't blow my car apart with my 406. Im lookin at getting sub-frame connectors, The Lower control arms and new panhard bar. Im just wondering if i need the adjustable stuff or not? what are the benifeits of this. Not to be mean to spohn but the site is kinda vague. Also i was lookin at the LCA and on the non-adjustable one it say nothing about using the original mount hardware like all the other ones. What gives or is this one of those"well i thought it was obvious" things. Oh ya does Spohn ship to Canada anyone know.
Reply 0
Jan 21, 2002 | 10:18 PM
The benefits of having the adjustable stuff is so you can tailor your suspension to suit you and the power of your car. The LCA's and torque arm are adjustable so you can set the pinion angle to where you want it. The panhard bar is adjustable becuase when you lower a car it shoves the rear end out of the center of the car. The only way to correct the problem is with an adjustable panhard bar. The none adjustable LCA's use the same mounts as your stock ones do. I'm not sure if Spohn ships to Canada,e-mail him and I'm sure he will get back with you,hes a great guy to deal with.
Reply 0
Jan 22, 2002 | 04:19 AM
With adjustable LCAs you can adjust your thrust angle. If you ever get your car aligned, you gotta let them know that or they'll assume it's not.
Reply 0
Subscribe
