rear?
Old Jan 23, 2002 | 10:45 AM
joemo22's Avatar
Car: 1989 Camaro
Engine: 383
rear?
I have an 89 RS and i need to know what type of rear I have is it a 10 bolt? Also will a 12 bolt posi work?
Old Jan 26, 2002 | 03:34 PM
ede's Avatar
ede
10 unless soemoen swapped in a 9 bolt, coult the bolts to be sure. after market 12 bolt will work as long as it's made for a thirdgen f body.
Old Jan 26, 2002 | 04:11 PM
Yvonne's Avatar
What rear is under here?
Count the number of bolts on the rear cover. Stock F-bodies usually had a 7.5-inch 10-bolt rear. Some had a Borg Warner 9-bolt rear. Do not rely on housing codes to identify what is in the rear, since most ratios have been changed and the rear can be converted from open to posi with a replacement center section. If you need anything, please email us at houser@rearman.com .
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
