Red Koni shocks
Car: 1983 Trans Am MSE
Engine: LG4
Transmission: TH700R4
Axle/Gears: 10 bolts 3.73
Red Koni shocks
Hi there,
I dropped the front shocks last week. These are red Koni as usual on the MSE. I was surprised there is almost no damping action in compression. Extension is well damped even at half setting but nothing in compression.
Is this normal or do i have to replace the shocks ?
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
Re: Red Koni shocks
They are most likey in need of help and have been on there since 83. Koni will rebuild them but its cheaper to just put them on the shelf and buy koni yellows
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: Red Koni shocks
You're talking about the front struts right? Koni yellow make a world of difference!!!
https://www.thirdgen.org/forums/whee...-pr148-oe.html
Engine: LG4
Re: Red Koni shocks
Ok so we agree they should be damping compression as well as rebound.
Thanks guys !
I'll get Koni yellow.
Thanks guys !
Re: Red Koni shocks
While compression and rebound settings aren't usually identical when optimum, the complete lack of one or the other is a serious problem.
Engine: LG4
Re: Red Koni shocks
That's the reason why i was asking.
No compression damping seems a bit weird for high speed driving.
I never drove that car so i couldn't say how it behaves. I'm working on it to get it back on the road.
Engine: LG4
Re: Red Koni shocks
DiabloWS6
21
Feb 7, 2012 02:59 PM
