Cluncking noise rear end
Hi!
So, i've a small issue with my car (that i'm fully rebuilding).
When parked, if i move the car side to side, there is a clunking noise coming from the rear end.
I did go under the car and i suppose that this noise is coming from the panhard / track bar.
For info, the bar mounted on the car look like this one UMI Performance UMI-201723-B Double Adjustable Panhard Bar & Lower Control Arm Kit (Black) | 82-02 Chevy Camaro/Pontiac Firebird | SD Wheel with spherical bearing rod ends.
Re: Cluncking noise rear end
More likely it's just the axles shifting in and out of the tubes. If you have a 10-bolt rear they'll generally move 2 -3mm. Completely normal.
Pretty much, yes. Ones with the 9-bolt don't. But any vehicle with a C-clip type rear axle, which means about 95% of all American rear-wheel-drive cars from the mid 60s up through today, will do that. Probably quite a few from other countries as well.
psychobowtie
Aug 30, 2004 09:56 PM
