Brake line securement to K-member
Old Aug 6, 2025 | 01:27 AM
CRAZYCHUCK13's Avatar
Car: 91 Z28
Engine: 383-Carb
Transmission: TH400/3500 Stall
I recently installed a UMI K Member,Looking for some ideas for attaching brake lines to k-member.help & suggestions are appreciated.
Old Aug 6, 2025 | 05:37 AM
Bald_eagle_machine's Avatar
Car: 1988 Trans am GTA
Engine: L98 350 TPI
Axle/Gears: Factory 9 bolt w/disc brakes
Re: Brake line securement to K-member
I used some big fat HVAC zip ties for mine. Never had an issue.
Old Aug 6, 2025 | 08:33 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I too used zip ties. You can also use hose clamps if you want something more robust.
Old Aug 6, 2025 | 09:57 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
if you want to be really fancy, you could drill and tap holes in the k-member to install brake line clips with bolts.
Old Aug 6, 2025 | 11:18 AM
BURD's Avatar
They make a metal zip tie, it won’t break.
Old Aug 7, 2025 | 10:43 AM
Toon86's Avatar
Car: 1986 Base Firebird
Engine: 2.8L MPI
Transmission: 4 Speed
Axle/Gears: 3.42:1
If you want to do a nice job and not have it fail you could use Rubber clamps. They are available at Princess Auto and I'm guessing Harbor Freight has them as well.
Old Aug 7, 2025 | 11:06 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I used those rubber clamps for a bunch of things work great and look good
MartinC
Brakes
Apr 11, 2006 07:35 AM
83 Crossfire TA
Oct 16, 2002 05:52 AM
