Sway Bar & link torque spec's
Old Mar 27, 2026 | 11:00 PM
TA392's Avatar
Anyone know the torque specs for the front sway bar bushings and sway bar end links for a 1984 Trans Am.
Old Mar 28, 2026 | 08:12 AM
Re: Sway Bar & link torque spec's
Torque on bushings = yes, tighten them; being about 10mm bolts IIRC, "tight" would be 35 ft-lbs or so
Torque on end links = tighten until elastic material deforms to slightly larger OD than the washers (required torque will depend on their material)
Old Mar 29, 2026 | 12:54 PM
TA392's Avatar
Got it, Thanks. Couple more question on a 1984 Trans Am sway bar bushings.
1) Split direction. On the front sway bar the splits on the factory original was to the back but some say it should face forward . Would it really make a differece ?
2) When ordering bushings. Description are "Front To Frame; 32mm Sway Bar Diameter; w/o Tabs on Mounting Clamps". What are ....Tabs on mounting clamps ?
The rear sway bar bushing splits were facing forward
Old Apr 1, 2026 | 09:54 AM
  1. I'm not very bright, butt I can't see what difference it would make.
  2. No idea. Never seen any "tabs" on any of those on any vehicle I've ever worked on.
84TranzAm
Jul 2, 2008 07:27 PM
86 sports coupe
Aug 28, 2005 10:03 PM
AndrewM
Sep 3, 2003 07:11 PM
