brakes binding?? I need help QUICK!
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
I pulled the wheels off the front today to do the brakes...and the rotors were VERY hard to turn. Now i know that's not normal, they're supposed to spin pretty freely...do you think that means my brakes binding? Also, i've been pretty disapointed in my cars performance lately, and if the brakes are binding, which is causing the wheels to be so hard to turn, then that explains why my car has felt so slow, and explains why my pads lasted only 11 months. Any suggestions? Thanks guys
Car: 1991 Firebird
Engine: 383 stroker
if they're original, the calipers probably need to be replaced. OEM's are pretty cheap, I think I only paid 14 buck each for mine. Here's another thought, did you ever take the rotors off and maybe torque down the spindle nuts to much? If you did, it can damage the wheel bearings and compromise the wheel turning.
Car: '89 RS
Engine: 9C1 w/ TPI
Car: 1991 Firebird
Engine: 383 stroker
venting the fluid resevoir will help the caliper pistons move back, but still shouldn't be hard enough to bend a C clamp. After awhile the pistons will just score in the bore and start to bind.
Fronzizzle
Mar 18, 2019 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
