Front to Rear weight ratio?
Old Feb 27, 2002 | 09:50 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
What is the front to rear weight ratio of the 3rd gen?
Old Feb 27, 2002 | 10:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's nose heavy. It might be 60/40 or higher.
Last fall I weighed my race car and it came out 58/42. It does have the added weight of the big block but also has a lot of factory weight removed.
Old Feb 28, 2002 | 01:26 AM
NickS's Avatar
Here's what I had for mine:
1992 Z28 + me (200 with helmet) + 12gal fuel
Total weight: 3233lbs
LF: 964 RF: 927
LR: 679 RR: 667
Front: 1891 = 58.4%
Rear: 1346 = 41.4%
Hope that helps
- Nick
Old Feb 28, 2002 | 01:30 AM
Engine: 305-4v
Thanks guys.
But with a 60/40 ratio, why does it handle so well?
Old Feb 28, 2002 | 01:37 AM
NickS's Avatar
A lot of factors go into why a car handles well, not just weight distribution.
I could go into them here, butI'd be typing for a longass time, but basically, a 50/50 weight distribution helps very little so do cross weights (mine are 1631 and 1606). More important factors are spring rates, anti-rollbar stiffness, shock dampening rates (bump and rebound), suspension geometry, camber, etc and probably the most important one - driver
- Nick
Old Feb 28, 2002 | 07:57 AM
Engine: 305-4v
Well then, I guess 11 years of driving taxi has had some benefits in my case
3rd gens sure do handle better than the 77-89 Impalas.
Old Feb 28, 2002 | 09:07 AM
82camaro's Avatar
Car: 82 camaro SC
What helps is that the suspension is set-up for the front heavy distribution--such as higher rate front springs and fatter sway bars.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
MORREALE5
Sep 13, 2015 09:16 PM
