ATTN: AndyZ28 , or anyone with pics of 1LE setup
hi,
at one point I think you had a really nice webpage comparing both setups with a lot of pics and showing how to modify a normal spindle into a 1LE spindle..
well I think I found 1LE setup on a junked car but I a not 100% sure , plus I can't look at it myself (friend found it in anothet state), so I REALLY need some pictures of 1LE setups and how I can tell it apart from normal 3rdgen brakes (there are no RPO codes in that car).
does the 1LE spindle have a small bracket on it ?
caliper will be a 2piston caliper right ?
11.87" rotors ? (12" rotors).
I would really appreciate it if you could post that pic of 1LE spindle next to a stock spindle.
I *think* I might be able to get the whole setup for cheap , so what should I grab ? rotors , calipers , spindles ?
thanks for any help you or anybody else can give me !
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You're right on. Dual piston aluminum caliper, bracket thingy on the spindle. Buy it! Cool find!! Pull of everything that's somewhat connected to the brakes.
Hotrodboba400
Dec 10, 2019 07:07 PM
