Pinion angle ? on BMR and modifing Hotchkis STB
Old Mar 12, 2002 | 09:45 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
First off since I replaced my motor mounts with ES poly mounts the car sits about 1/2 in higher then my stb bar can go. I have placed 2 washers unfer the base of the mount and it worked, but then i tried to shut the hood and the top hits the hood. (firebird) so i took out a washer and it basrely fit like within a 1/16. The hood JUST made it but when i started it up the motor hit the bar and it started to vibrate. My question is can i grind some material off the front bar of the STB on the bottom? I wont be touching the other back bar or the plate welded across. I feel this is the only way to go.
Also on my BMR TA, I am trying to adjust the pinion angle but am having a hell of a time. The TA came with a pinion angle finder and it seems to work good. but when I had the rear at a -5 and the DS at +4 which got me the -1 the rear and the DS were way in a V shape Now I have the Rear -2 and the DS at 0 which gives me -2? Am i missing something here ? Also when I had the first combo the arm itself was so far through the bushing that it was aboiut I kid you not 1/16 behind the VSS sensor. and I was afraid that If i hit a bumb that would be it. Now with the second combo I have about an inch to spare.
Old Mar 13, 2002 | 12:03 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Re: Pinion angle ? on BMR and modifing Hotchkis STB
I'm not sure on that STB, but isn't the STB's bar hollow? If you grind that, won't it leave a hole in the STB tubing?
Old Mar 14, 2002 | 05:56 PM
cort351w's Avatar
Yeah, the STB is hollow.
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
gord327
Sep 29, 2015 10:18 PM
