Alignment Specs
Old Mar 16, 2002 | 01:52 PM
Eric91Z's Avatar
Car: 2004 Mercury Marauder
Engine: 4.6L DOHC
Transmission: 4R75
Axle/Gears: 4.10 gears/8.8 rear
Alignment Specs
Well, finally getting a long over due alignment done on the car. These are the specs I am shooting for (or as close as possible):
Caster: +4.5
Camber: -1.0
Toe: 1/16 in OR 0
Any thoughts or input?
Old Mar 17, 2002 | 11:29 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: Alignment Specs
Caster: +4.5
Camber: -1.0
Toe: 1/16 in OR 0
-1.0 camber will result is great cornering at the expense of inside tire wear. use -0.5. as far as caster goes make sure you have .5 degree higher on the right side so it will go straight. road crowns to the right. if you have equal caster, it will drift right. so, you put .5 degree higher to offset the road crown. use 1/16 for teh total toe. 0 can result in wandering.
Old Mar 18, 2002 | 07:09 AM
82camaro's Avatar
Car: 82 camaro SC
I agree, on the street you won't want -1.0 camber. You will gain very little performance and hurt the tires compared to -.5
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
