radiator question
Old Apr 21, 2002 | 10:04 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
radiator question
can i blow my radiator out with compressed air or even high pressure water (not too high pressure). i dont think it is clogged up or anything i was just wondering.
thanks
Old Apr 22, 2002 | 01:07 AM
poncho9789's Avatar
If you are talking about the outside yes but if you are talking about the inside it would be difficult to do but it is possiable to do. I don't know how much of a result you would get by doing it. Your best bet if it is cloged on the inside you should take it to a radiator shop and have them rod out the radiator and it will clean it like it was a new radiator.
If it is an aluminum/plastic radiator then you should really let a shop clean the inside so you dont' dammage the fine cooling fins.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
Clean87TA
Sep 4, 2015 11:23 PM
redmaroz
Aug 16, 2015 11:40 PM
