Possible to use a TPI Fuel Pump with my TBI??
Old Apr 28, 2002 | 08:55 AM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
The fuel pump on my RS I am pretty sure went out, I don't hear it coming on when I turn the key. I have a Holley TPI fuel pump which is actually made by Walbro. Since we have pressure regulators would this work?
Old Apr 28, 2002 | 02:55 PM
NotDadsW41's Avatar
You can use it. BUT you will need an adjustable fuel pressure regulator of sort installed first. You will need a fuel pressure gauge and will need to turn the regulator down somewhat from the stock setting.
I am running a fuel pump for a LT1 powered b-body in my 89 9C1. It delivers about 10psi more pressure than the stock one did.....
Old Apr 28, 2002 | 04:07 PM
Car: 1992 Camaro
Engine: 350 miniram
I am curious why your fuel pressure increased by 10 PSI when you put in a LT1 pump. I didn't plan on a adjustable fuel pressure regulator either, since the motor is basically stock I figure what ever the stock regulator lets through would do.
My thought is that even though the TPI pump puts out a higher PSI the stock TBI fuel pressure regulator would only let a given pressure through, whatever it is like 10 PSI. Any other opinions if I can do this with a stock pressure regulator and a TPI pump?
Old Apr 28, 2002 | 08:39 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
It will be fine. I just did mine and there was no change. The holly 255 lph pump is for TPI & TBI so a stock TPI pump should work in a TBI car.
Old Apr 28, 2002 | 08:46 PM
NotDadsW41's Avatar
I think it was a matter of the volume of fuel being moved. That and I had been playing with the vAFPR for sometime with a weak pump. When I switched to the LT1 pump, I went from 12psi at idle to 22 when I first started the car. Of course I shut it down right away and adjusted the pressure down.
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
