TPI fuel pump?
Subscribe
May 1, 2002 | 02:31 PM
I think my fuel pump is acting flaky...I really need to get a gauge to tell for sure, but no one makes a large 30 psi gauge
I've seen the 255 LPH TPI fuel pump in Jegs and Summit...can I use this pump? I've been told it'll work ok but I want to make sure before I drop my gas tank. Will I need an adjustable regulator?
Reply 0
May 1, 2002 | 03:31 PM
What kind of quage are you using now?
Reply 0
May 1, 2002 | 03:57 PM
Quote:
I don't have one
Reply 0
May 1, 2002 | 05:51 PM
Ok.
I installed a Nordskog in the dash. Everthing else I have is Autometer but I just didn't feel like shelling out $180 for one. You can get the Nordskog sending unit and the cheaper guage for around $80-90 if I remember www.nordskogperformance.com from Summit
Reply 0
Mar 28, 2003 | 06:42 PM
Astro Captian,
Which pump did you end up going with?? My stock tbi pump can't push more than 15psi. I would like about 23psi. DOes you new pump directly replace the tbi pump, as far as in tank mounting goes??
Reply 0
Subscribe
