Bog on warm startup?
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
I've had this problem since last summer. When my car is warm, and I start it, it'll start just great, aut then the RPM's will drop to the point where it almost dies, and it will blow out a puff of black smoke. Nothing else is wrong, it'll idle fine, runs great (other than my newly-developed tranny problem.) Seems like it's running rich right after it starts, but then it runs great.
Car: C1500
My thoughts in order:
Bad CTS(Coolant Temp Sensor)
Bad IAC
Bad MAP
Vacuum Leak to MAP
Leaky Injectors
High Fuel Pressure
That's all I can think of right now, somebody should be able to jump in and tell you exactly what it is.
Bad IAC
Bad MAP
Vacuum Leak to MAP
Leaky Injectors
High Fuel Pressure
IAC, that's the little thingy that I took out of my air filter when I went to open element? Isn't it the samne as CTS?
well, it's sitting in the engine bay near where it used to be, does it make any difference on placement?
Car: C1500
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
