TBI timing question
Old May 13, 2002 | 06:59 AM
TBI305Camaro's Avatar
TBI timing question
ok i have a question about the computer controlled timing. if i set it at 0 degrees (yes EST disconnected) then connect the EST back and start it again it will jump to 12 dgrees base...but if i set the timing to 12 with it diconnected then connect it it jumps over to like 20 or something. the computer knows whats up right and it shouldnt be knocking or pinging to bad right? im running 93 octane in it so that might be why
Old May 13, 2002 | 01:22 PM
Dex's Avatar
Dex
Umm the computer advances your timing so when you pluged it back in the computer advanced it and I bet with it pluged in and you hit the throttle it jumped even farther
So set your base timing with it unpluged the plug it in tighten the dist. remove the timing light shut the hood and enjoy the ride:lala:
MustangBeater20
Oct 29, 2022 09:20 PM
dutch930
Sep 11, 2015 06:58 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
