good heads!!!
Old May 18, 2002 | 08:07 PM
sublime7880's Avatar
good heads!!!
im going to rebuild my 89 rs in a couple weeks.... im going to swap out the cam for a lt1. what would be a good set of CHEAP heads to put in?? 305 tpi? L69? or should i just port mine? help!!!!
Old May 18, 2002 | 09:48 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
I believe TPI and TBI heads would be the same. I was told to expect at least 15% better flow out of my stock heads with some porting and unshrouding of the valves. I think the extra money is better spent on headers. I guess I'll know if I made the right choices when I turn the key!
Old May 18, 2002 | 10:06 PM
NTChrist's Avatar
The TPI and TBI heads are not the same. There are major differences.
Sublime: Try a search on this topic. There has been a lot of good discussions about this lately.
In short, the stock heads are usless without a lot of porting. While reading the previous threads, look for references to a "swirl" in the intake port.
Come back with a specific question, and one of us will happily answer it.
Old May 18, 2002 | 10:11 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
dont port the stock heads. for cheapness i would get some TPI ones and try to do some porting on those if you want
Old May 18, 2002 | 11:01 PM
steve8586iroc's Avatar
If you have access to the TPI or L69 heads for cheap and they don't need a rebuild then just take your pick, they are the same, no differance, nada, none. Of course aluminum L98 heads would do ok too.
Steve
Old May 19, 2002 | 09:22 AM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
Thanks for catching my mistake!
Old May 20, 2002 | 03:59 PM
iroc22's Avatar
The most common 416 castings (L69, LG4, LB9) are the best factory 305 heads for performance. If you want to go cheap, then nab yourself a set of these. Unfortunately though they are perimeter bolt style heads that dont retain the valve covers as well....
The 081 87-92 LB9 heads are based on the above runners with slightly improved combustion chambers and have the about the same power increases. They have the centerbolt holes.
There are major differences between the 187 (L03) and above 416,081 castings. There are cast in swirls before the intake valves. There are valve shrouds in the intake runners right before the intake valves. The 187 heads are a good midrange torque building head, excellent for towing; and not a performance casting.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
