fuel pump, 02 sensors
ok guys, would u think a faulty fuel pump will cause hesitation, since it would be pumpin out too little fuel?? and how bout o2 sensors, would that cause hesitation, and last how can i make sure my timing is correct, so i dont have hesitaion, thanks
Car: 88 ext.longbed 1/2 ton
Engine: TPI 350
Transmission: Slushbox 400
Yes the fuel pump can cause hesitation and when it gets real bad it should throw a lean exhaust code.
On the timing issue you just make sure the base timing is set properly.
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
