another 400 update
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
another 400 update
well, the new engine's sitting the car right now. went in much easier than the old one came out, maybe cause i didnt put the tranny in yet (sitting in the garage in the middle of a rebuild)
. broke down and bought the holley tbi adapter plate instead of machining one. got the driver side header on, the passenger will require me to remove the starter. should hopefully be up and running (on the stock 305 ecm at the moment) by this weekend. have a caprice cop chip sitting right here, but gotta order one of the chip adapters so i dont have to unsolder and possibly burn up the chip i got now. did the ultimate tbi mods including afpr and have 350 injectors, so that will hold me over for now hopefully. any other good ideas/questions/comments, lemme here them. always up for suggestions. thanks
. broke down and bought the holley tbi adapter plate instead of machining one. got the driver side header on, the passenger will require me to remove the starter. should hopefully be up and running (on the stock 305 ecm at the moment) by this weekend. have a caprice cop chip sitting right here, but gotta order one of the chip adapters so i dont have to unsolder and possibly burn up the chip i got now. did the ultimate tbi mods including afpr and have 350 injectors, so that will hold me over for now hopefully. any other good ideas/questions/comments, lemme here them. always up for suggestions. thanks soudns really good.
you have your motor in and i am still trying to get money to take my block to the machine shop....lol
did you use a stock 400 bottom end or did you upgrade to longer rods and stuff?
i am gonna get a new lighter crank and a set of 6inch rods for mine
later
tim
later
tim
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
due to my limited funds and lack of time, i used everything that was already in it. not sure about rod length (never measured), but i had to get a new crank because the one that was in there was bad. the rest of the block was immaculate and since i'm not gonna be using this as an all out drag car, i didnt bother to take it to the shop. hopefully should be up and running in the next couple days. only thing i'm waiting on is finishing the tranny. 90% done and hopefully it'll run right. if not, i'll take the loss in mpg and money and put the th350 in it until i can buy another 700r4.
2012sergen11
Oct 13, 2015 07:38 PM
