Does my 92 Camaro TBI have a MAP sensor or an MAF sensor?
Old Sep 2, 2002 | 11:13 PM
Red_Demon's Avatar
From: Currently State College Pa, Usually, I live out side of philly.
I need to know what to buy to try to solve my problem..
another quick question... when I replace either the MAP or the MAF do I have to pick one up for a caprice 350 with TBI since I replaced the 305 with a caprice 350??
Old Sep 2, 2002 | 11:17 PM
NJ SPEEDER's Avatar
our cars have a MAP sensor. it hangs on the firewall on that little spot that sticks out. they don't really go bad unless you smash it, just make sure the vacuum line leadign to it is good and sealed well at both ends. a vacuum leak will cause it to read all screwy.
also, all of the gm cars taht used a MAP used the same one. so 305 or 350 does not make a difference.(that includes my '84 cav)
later
tim
Old Sep 2, 2002 | 11:36 PM
Red_Demon's Avatar
so map sensors are hard to make go bad? I wonder what could be causing my problems then...
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
