Fuel pressure questions inside.....
Old Sep 24, 2002 | 06:26 PM
84 Challenge's Avatar
I have an 84 Iron Duke Camaro. Recently replaced the fuel pump, filter & relay. Still no fuel! Are there some sort of procedures to release the fuel pressure? If so, I just started to work on the fuel system without thinking about this. Do I need to somehow re-obtain fuel pressure after replacing these pieces? What else could cause no fuel to begin with.....clogged injector? Should I start replacing parts instead of towing to a local garage? Any help would be appreciated!
Thanks,
Brandon
Old Sep 24, 2002 | 08:22 PM
NJ SPEEDER's Avatar
check to see if you are getting spark first. if you are missing spark and fuel then your not getting ignition signal. check for a bad connector or dead wires on the distrib.
to relieve fuel system pressure just undo the gas cap.
later
tim
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
