Code 45 -- Rich Exhaust
Old Sep 27, 2002 | 03:56 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
As the subject says I am having a problem with a rough idle and setting code 45. This only happens when the truck is warm, when cold it idles fine. This is an '87 GMC with a 350 tbi.
If, after the truck warms up, I sit at a light the idle gets very rough and throws a code 45. I have diacom data which shows the O2 sensor reading (constantly) above 900mv during this time, and of course it goes in to open loop. All other sensors read normally. Immediately after hitting the gas a little the ses light goes off and it goes back to closed loop. The truck accelerates and runs smoothly, just problematic at idle.
I have tried all of the following (only ac delco parts used):
Replaced EGR valve
Replaced all plug wires
Replaced dis. cap and rotor
Replace all plugs (they looked normal though, nice tan/white)
Replaced O2 sensor (that also looked normal, no carbon build up)
Replaced air filter
Replaced evap. can. filter
Replaced fuel filter
Replaced fuel pressure regulator
Replaced both fuel injectors
Replaced MAP sensor
Fuel pressure is normal
Return line is not clogged
There is no fuel in the evap. can. line
PCV system is working normally
The gas mileage is normal
I triple checked and there are no vacuum leaks
Vacuum at idle is normal, until code is thrown, at which time the vacuum drops (as if under load)
Any comments/suggestions would be GREATLY appreciated.
Old Oct 2, 2002 | 02:40 PM
loudpedal's Avatar
Car: DAF
Engine: 3 cyl 2 cycle
Transmission: variable speed
ty the one thing left......
TPS
as u have a scanner check the values first.
a long shot.......fuel diluded oil?
Dyno Don
Jan 24, 2016 08:24 AM
GTAman
Sep 21, 2015 09:57 AM
RyanJB
Sep 2, 2015 01:27 PM
