l31 and lo5 block
Old Oct 9, 2002 | 03:09 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
l31 and lo5 block
what is the difference between the l31 and the lo5 block and how can you tell them apart visually.
Old Oct 9, 2002 | 03:16 PM
NJ SPEEDER's Avatar
i don't think there is any difference in them really. i am starting to see a serious pattern of people worrying about which block they get. as long as you get a block that has no cracks or anything in it you are in good shape. most blocks cast after 1987 have the provisions for the roller cams already drilled adn tapped and the blocks that are not drilled and tapped still have the raised spots to put the holes in. many truck and marine application blocks were not tapped and most of the passenger car ones were.
any 350 block will do, especially if you intend to swap cams and stuff anyway.
later
tim
sheachopper
Jul 31, 2019 11:27 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
