Need Help with stumbling
Old Oct 13, 2002 | 12:02 PM
kingrobert's Avatar
Hey all, I've been trying to solve a stumbling problem with my car, I have an 88 305tbi. I've already changed the MAP sensor, TPS, rebuilt the tbi, and checked the wires, cap, rotor, coil, and plugs. When the car is running, it jumps from 600 to 1200. I can unplug the MAP sensor and the car will idle at 1100. I was wondering what else might be causing it to stumble, thanks in advance
Old Oct 14, 2002 | 03:40 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
When you unplug the MAP sensor are you unplugging the electrical or the vacuum line.
Old Oct 14, 2002 | 04:12 PM
kingrobert's Avatar
vacuum line
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Logan Bryant
Sep 23, 2015 06:51 AM
RedLeader289
Sep 23, 2015 06:50 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
