Error Reading
Old Oct 17, 2002 | 04:28 PM
vrooom305's Avatar
Error Reading
How do I check for errors that the car is making?
Old Oct 17, 2002 | 06:41 PM
deadtrend1's Avatar
Are you talking about error codes??? If so the simplest way is to take a paper clip and ground on the diagnostics terminal for your ECM. Buy a haynes manual and it will tell you how to do it in there.
Later,
~Tim
Oh yea, you spelled camaro wrong in your sig....
Old Oct 18, 2002 | 02:21 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Put the paper clip between the top right 2 holes in the ALDL plug under your steering column and that will cause your check engine light to blink the codes with the ignition key on and engine off.
Old Oct 19, 2002 | 04:16 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Easiest way is to put it on a scanner.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
