2nd gear bogg, 250L6/TBI
Old Oct 22, 2002 | 12:32 AM
CHEVYTOWN's Avatar
Bogging at WOT 250L6/TBI
Scratch everything...it boggs at WOT period. Doesn't matter what gear I'm in.
Anyone from Souther Cali know someone that tunes GM TBI's? I'm guessing I can send the Prom to Howell and have them hook it up and do what they gotsta do, but that wil take some down time.....so I don't mind paying the hefty fine for the quick fix.
Any help greatly appreciated HOMETOWNS...
CHEVYTOWN
Old Oct 22, 2002 | 07:17 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
WINALDL will confirm the problem but I am betting that it is running a little lean and causing your bog. An increase in fuel pressure should improve or eliminate the problem.
Old Oct 22, 2002 | 05:13 PM
CHEVYTOWN's Avatar
Can someone in here sell me a cable? I have a PC with WINaldl installed.
What should I be looking for once inside the WINaldl program...what part of the program will tell me what's going on with this bogg...
I can't figure out where to adjust the fuel pressure. Is it done to the prom? Or can it manually be adjusted...I'll do a search and see what I can find...
Thanks hometown for your help, CHEVYTOWN
Old Oct 23, 2002 | 08:05 AM
The regulator is the round thing in the back of the injector pod on your tbi unit. You will either need an adjustable regulator or make yours adjustable. I am not sure if there is a tech article on it or not.
It would also be nice if you had a summit 0-30 psi gauge plumbed into the fuel supply line so you can know how much you increased the pressure.
I would offer to make the cable but I am still working on my soldering skill and then I will offer them reasonable on my website once I get it mastered.
Old Oct 23, 2002 | 04:14 PM
deadtrend1's Avatar
The cable seems tricky to do at first, but if you go step by step .. it takes 5 min. Just one trip to radio shack ....
Old Oct 23, 2002 | 04:31 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
i have a cable at home that i dont use... I built a serial port right into my dash so i dont need the cable anymore. $10 and and ill ship it to ya. Wont be home till the weekend so youll have to wait untill then. Drop me a pm and well take it from there.
Old Oct 23, 2002 | 05:28 PM
CHEVYTOWN's Avatar
Bogging at WOT
No go man, it's still doing it and I was wrong about one thing, it doesn't matter what gear I am in. I think I'll print all the information and send it to Howell. They do custom chips. I only damn wish I could do it myself. But to get the burner and tunercat is just too much dough right now(just had a 2004R installed, broke the bank). Howell charges $150 for a custom chip. Pricey, but it will get me going down the road with the TBI properly tuned....
Chevytown
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
georgiaslim45
Sep 9, 2015 08:12 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
