What Is This....
Old Oct 29, 2002 | 08:31 PM
88TRANS's Avatar
What Is This....
FORGIVE MY IGNORANCE. I HAVE AN 88T/A WITH A 305TBI. DIRECTLY BEHIND THE A/C COMPRESSOR ON THE PASSENGER SIDE IS A BLACK BOX WITH HOSES ATTACHED TO IT. IT MAKES ALOT OF NOISE. IT RATTLES AND PUTTS ALOT. IT SEEMS TO HAVE AN OPEN HOLE ON THE BOTTOM OF IT WHICH ALLOWS PRESSURE OUT. IF I BLOCK IT WITH MY FINGER IT STOPS MAKING NOISE. WHAT SYSTEM IS THIS ASSOCIATED WITH ..IS THERE ANY REPLAEABLE STUFF UNDER/IN IT. ANYWAY TO KNOW IF ITS OPERATING CORRECTLY...
Old Oct 29, 2002 | 08:35 PM
NJ SPEEDER's Avatar
taht si the box for the A.I.R. lines that lead to the exhuast manifolds. it is a part of teh emissions system for cold starts to get teh cat up to operating temp faster.you can plug it or remove teh pump from the accesary system along with all the othe rtubes without any ill effects.
later
tim
Old Oct 29, 2002 | 11:07 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
Does any body know what belt i need if i take off the smog pump plus i have the 3 piece under drive pully kit
Old Oct 30, 2002 | 12:51 AM
deadtrend1's Avatar
93.5 inch 6 ribbed belt ... Im pretty sure thats it cause the underdrive pulleys tool like 3 inches off the belt, but removeing the pump added 3. I'm almost positive it went back to the stock size/
GTAman
Jul 3, 2024 07:29 PM
luvofjah
Sep 26, 2015 08:28 PM
gusman
May 27, 2004 12:07 PM
PMGCamaro
May 13, 2004 07:15 PM
Street Lethal
Sep 14, 2003 01:54 PM
