Possible bad O2 sensor?
Old Dec 20, 2002 | 03:32 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I was running pig rich the past couple of days to the point where it'd be dumping too much fuel in at idle and just die out when I was sitting at lights. I hooked winaldl up today and was tagging .950 just driving around normally, but my blms were constant at 128 the whole time. I pulled the fuel pressure down a lot, aucutally to the stock setting which was dead center on the regulator and my voltage dropped to about .800 driving around, but spikes to .950 quite a bit still, and this isnt even under wot. My blms dropped to between 108 and 124 most of the time, which would imply a lean condition, but my O2 sensor still tells a rich condition?
Any ideas? Thanks!
Old Dec 20, 2002 | 07:33 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Here's a big question: by WinALDL, is the ECM going into closed loop mode (or learn mode)? Try dropping the fuel pressure even further - the BLMs should, theoretically, shoot above 128 to signify that the ECM is compensating by adding pulse width to the injectors.
Old Dec 20, 2002 | 08:21 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Actually, a number less than 128 indicates you're running rich, and vise versa. 108 is extremely rich.
Old Dec 20, 2002 | 08:48 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
So its still that rich with the fuel pressure at stock setting?
I dont have egr anymore, I dont think it goes into closed loop does it?
Old Dec 20, 2002 | 11:21 PM
Engine: LO3;383tpi
I'm not sure if it goes into closed loop or not. There should be a flag data for it. Once your engine gets to operating temp, check the flag data in WinALDL.
Old Dec 21, 2002 | 09:48 AM
JPrevost's Avatar
Car: 91 Red Sled
It'll still go into closed loop without EGR. Definatly check the flag data to make sure it's in closed loop. I would still replace the o2 sensor with a heated version if you're into burning eproms .
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
GTAman
Sep 21, 2015 09:57 AM
