Failed emissions test....NOX too high...??s
Old Dec 22, 2002 | 09:15 AM
super chevy's Avatar
My '93 Silverado failed the Dallas County sniffer test Friday. My NOX levels were too high. Tech said that is usually an indication of too hot of a combustion chamber. Probable EGR failure. Might also be too lean.
I'm going back for a retest on Monday.
I've already pulled the intake off and cleaned EGR ports as well as installed a new EGR valve and EGR solenoid, and new AC spark plugs. Reset timing back to factory spec of TDC.
Anything else I can do?
Was told might be a plugged catalytic converter causing the high chamber temps.
Is my open element air filter pulling in too much air?
Any ideas?
Thanks for the help,
SC
Old Dec 22, 2002 | 11:32 AM
XxPichulonxX's Avatar
make sure u check that the TPS isn't outta wack with a voltmeter
Old Dec 22, 2002 | 12:01 PM
Will do, Pichulon.
Old Dec 22, 2002 | 02:09 PM
jase's Avatar
I notice that you are using a 180 stat.Would a 195 stat help you out by getting the engine to it's operating temps and burn alittle better?Just a thought to try and help you out and that might not be the problem.
Old Dec 22, 2002 | 06:50 PM
I swapped to a 195 last month when the weather got cooler.
I changed back to the stock PROM today, and taped off 3/4's of the inside of my 14x5 open element filter to reduce the airflow into the tb.
All this in hopes of passing tomorrow.
I'm not throwing any codes, so I guess if it doesn't pass tomorrow, I'll put on a new catalytic converter and try again.
SC
Old Dec 22, 2002 | 07:23 PM
JPrevost's Avatar
Car: 91 Red Sled
A functional thermostat and fan that keeps the engine below 210 and above 180 is best for getting through the Nox testing. I passed with the 330hp crate motor which doesn't have EGR. I just had to run the car with a little more fuel to keep the combustion temps down and not as much timing while keeping the car cool. The trade off is higher hydro-carbons but lower Nox. The balance was in tuning the eprom.
Old Dec 23, 2002 | 03:49 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
I bet that you are probably running lean. But it may also be a bad cat. It is a good idea to get the car nice and hot when you take it in. When that cat is nice and hot it burns everything off better.
Old Dec 24, 2002 | 10:41 AM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Except that the 180 stat may actually reduce his NOx emissions...if the HC was nowhere near failing level, that might be a good start. Furthermore, if the HC *was* nowhere near failing level, I don't think the cat is the problem, since TBI cars NEED them to pass.
Old Dec 24, 2002 | 11:46 AM
Well, I passed yesterday....barely.
My Nox levels dropped from 1600 to 660 on the high and low speed test, while my previously very low HC's jumped to the limit - in fact, the low speed HC max is 147 and I had a reading of ... 147!
That's cutting it close!
The engine was at about 150 degrees temp when tested - helped the Nox reading, but almost got me on the Hc's.
Also, I had reconnected the vacuum line to my vAFPR for this test to get a little more fuel in there.
Thanks for the help guys.
SC
Old Dec 24, 2002 | 12:22 PM
fast_broker's Avatar
My bet was that it was the retarding of the timing that helped you.
Make sure you remember what you did for next time...
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
6998poncho
Sep 25, 2015 02:56 PM
