TBI Fuel Lines
Old Dec 26, 2002 | 10:48 AM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
TBI Fuel Lines
Am wondering if anyone has found braided fuel lines that will work on stock TBI units? I searched the boards for info on this but came up empty (please forgive and direct if this has been covered). Also checked summit, but they have nothing in particular.
I have dealt with the stock TBI fuel lines in the past and they are really tough to install, but with the new manifold I am trying, they just will not work.
Any help is appreciated-
Hope all had a good holiday-
Old Dec 26, 2002 | 11:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TBI Fuel Lines
Are you thinking of AN lines? If so there are adaptors that fit the TBI fittings and feed lines to change from the Saginaw to -6 AN. Can then use -6 line and fittings.
There are also some Chevy pickups that come stock with braided steel flex line (like AN). I don't have much info on them though.
RBob.
Old Dec 26, 2002 | 11:43 AM
Car: 1991 RS
RBob-
Thanks for the info. My lack of vocabulary (Saginaw and AN) were likely limiting my searches. I will look for those adapters and that should take care of me.
Thanks much-
Old Dec 26, 2002 | 01:53 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
If you look on the mods then fuel lines page of Z28 Boy's webpage it tells just about everything you'd ever need to know
http://z28boy.cz28.com
Old Dec 26, 2002 | 03:01 PM
Car: 1991 RS
Chuck!
Cool, thanks will look there also.
Thanks for your time-
I also found some good descriptive info (Pics of AN and quick disconnect fittings) on the diy-efi.org site.
Old Dec 27, 2002 | 12:58 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Chuck!
HTH's:
AN to Saginaw:
http://www.holley.com/HiOctn/ProdLin...A/9894DBH.html
9894DBH Female 14mm x 1.5" to -6: Fuel Injection Female "O" Ring Seal
9894DBJ Female 16mm x 1.5" to -6: Fuel Injection Female "O" Ring Seal
991954 14mm x 1.50" to -6: Power Steering / Fuel Injection - "O" Ring Seal
991955 16mm x 1.50" to -6: Power Steering / Fuel Injection - "O" Ring Seal
RBob.
Old Mar 11, 2014 | 11:45 AM
sootie007's Avatar
Car: 91 RS VERT
Engine: 305 9.67 2.02 58 cc 282 480 108 LC
Axle/Gears: 4.11 POSI
Re: TBI Fuel Lines
Not to resurrect an old thread but great info on AN fittings needed for TBI fuel supply and return lines going to carb or tbi ...........
http://z28boy.cz28.com/mods-fuellines.htm
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
