TBI into non-computer vehicle?
Old Jan 6, 2003 | 02:54 AM
IOwnCalculus's Avatar
Someone over at www.67-72chevytrucks.com pointed me in the direction of this site...
Anyway. I want to get a fuel-injection setup for my truck (a 1970 GMC, with a 350/Vortec heads under the hood...possibly eventually a 383). Doing a bit of research, it seems that a TBI setup will not only be easier than a TPI to install, but be cheaper (no $300 Vortec baseplate) and higher performing (I do want to run it past 4800RPM).
So, what am I looking at to convert to TBI? My engine as it sits with a 750cfm Quadrajet is pushing about 250hp...the farthest I'll take it anytime soon is to about 350hp, maybe a little more (that would be a Comp Cams XE256H cam, headers, and a 383 bottom end). From what I can tell so far, I'd need a throttle body complete with the IAC and injectors, an electric fuel pump and return line, an adapter plate to bolt the throttle body to the Edelbrock Performer Vortec, an ECM, a chip programmer/eraser, and a computer-controlled HEI to replace the vacuum/mechanical HEI in it now.
Is there anything I'm forgetting? What sensors does the ECM need for a TBI - namely, would I need to rig up a speedometer setup for my 700R4 so I can use my mechanical speedo but send a signal to the ECM? What vehicles are good sources for easily reprogrammable computers / other parts?
Possibly most importantly...how much money would I be looking at spending?
Old Jan 6, 2003 | 04:24 PM
NJ SPEEDER's Avatar
you can grab pretty much everything you need form yoru local salvage yard really. just look for a 350 powered tbi vhicle adn start pulling everything. i have never grabbed a whole system form a yard, but i have heard that they usually charge between 150 and 200 to grab everything needed. you will jsut want to pop in a fresh O2 sensor and you shoudl be in pretty good shape.
i forget what year gm stopped using cable driven speedo's, but i seem to remeber them having a set up that was good for signal and for teh speedo. look under mid 80's period rear drive vehicles and see if you can find one. it woudl be a kinda oversized looking cable drive speedo set up.
good luck with your swap.
later
tim
Old Jan 6, 2003 | 04:31 PM
I take it, then, that the TBI ECM does require the vehicle's speed?
Old Jan 6, 2003 | 04:53 PM
Keith5's Avatar
Car: C1500
He have to have the vehicles speed would he? That's only for the torque converter lockup and the speed limiter isn't it?
Old Jan 6, 2003 | 05:30 PM
If that's true, then I don't need the speed to the ECM...I have the TCC controlled simply by a series of switches (4th gear, engine vacuum, brake light) and I certainly don't want / will encounter a speed limiter. I'd just as soon set the ECM up as if it was hooked into a car with a manual transmission, since I already rewired my 700R4 when I put it in to get it away from the computer-controlled version.
Old Jan 6, 2003 | 06:00 PM
NJ SPEEDER's Avatar
i don't think it will effect teh ecm too much, but it certainly helps when datalogging to compare air/fuel or blm to vehicle speed and throttle position.
later
tim
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
327IROC85
Sep 23, 2015 12:11 AM
Formula8r89
Sep 22, 2015 04:24 PM
amcnellis
Sep 16, 2015 04:16 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
