Finally no more swirl ports
Old Feb 13, 2003 | 01:53 PM
ZRATED's Avatar
I finally got done with my head and intake swap. I ripped off the ol swirl ports and went with a pair of 305TPI heads (181s i think) that were ported and polished with new Z 28 springs and a new polished RPM air gap to go with that. When i first removed the heads i finally got to see the dreded swirl port heads, it was worse than i thought when i looked in the intake with the valves off. The car pulls much better into the top end but it still needs a lil bit of tunning. I have the holley 670 unit but i have not put it on yet do you all think I need it or is it over kill for what i have
If i put on the holley unit I will not be able to run the NOS plate becuase of the holley 2" bore. Can i enlarge the Nos tbi plate to 2 "?
Michael
Old Feb 13, 2003 | 01:55 PM
ZRATED's Avatar
another
Old Feb 13, 2003 | 01:59 PM
ZRATED's Avatar
swirl ports
Old Feb 13, 2003 | 02:09 PM
ZRATED's Avatar
pic
Old Feb 13, 2003 | 02:54 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Hey Zrated that looks really good man. I am still contemplating what manifold to get for my combo too. Do you still have the stock RS hood? If so how tall is that adapter plate and what kind of air cleaner are you using to make it fit and how much clearance do you still have?
Old Feb 13, 2003 | 05:22 PM
ZRATED's Avatar
I was trying to post more pics of the swirl ports earlier but it did not work
Old Feb 13, 2003 | 05:25 PM
ZRATED's Avatar
I have the SS hood and it fits very nicely under the hood the whole set up is about 2" taller than stock so it will not fit under a stock hood
Old Feb 13, 2003 | 05:55 PM
BronYrAur's Avatar
Engine: 305 TBI
Ok that makes sense that you have the SS hood; that's too bad I was really hoping you still had a stock hood and it would fit by some phenomenon, but it was just wishful dreaming I guess an air gap and a tbi adapter wouldn't fit under a stock hood.
Old Feb 13, 2003 | 06:22 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
about the nos plate all you need to do is order one for a 454 tb it has the 2 inch bores
Old Feb 13, 2003 | 08:19 PM
iroc22's Avatar
Your 187 castings look a little rough from that pic. How many miles did they have?
Old Feb 14, 2003 | 01:40 AM
ZRATED's Avatar
they had about 140k and yea they do look kinda rough
Old Feb 14, 2003 | 08:46 AM
ZRATED's Avatar
How much does the plate cost and where can I order it from?
Old Feb 15, 2003 | 06:28 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
You got some bling-bling goin' on with that engine compartment.
Mark_ZZ3
May 24, 2018 01:02 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
sammy52401
Nov 11, 2015 07:20 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
