Does the ecm have to be changed when going to a 350 tbi?
Old Mar 7, 2003 | 03:07 PM
JDV's Avatar
JDV
I have a 89 350(L98) coming in,and want to know if I have to change the Computer when I put this motor in or do I just find a chip for a 350. Also is there anything else that I will have to do. I was going to make this a Tpi engine,but I just thought that would be alot of work. And this would be a little easier. Thanks.
Old Mar 7, 2003 | 04:24 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Does the ecm have to be changed when going to a 350 tbi?
NOope, the '8746 will do just fine. Upgrade to 350 injectors and a 350 chip and go. Search the TBI board using these keywords (or mix thereof): ANLU, cop, 350.
RBob.
Old Mar 7, 2003 | 05:57 PM
vwdave's Avatar
I am in the middle of this swap with my car. I bought a chip and injectors from a 9C1 cop car. I'll let you know how it goes. (Hopefully it'll finally start tommorow. )
Old Mar 7, 2003 | 08:56 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
You need to get the 350 ESC Module and the 350 Knock sensor too. This is not a option you have to have these two parts for your moter to run well over 4000 rpm's Ill get you the part numbers soon. I know for a fact you have too use these part's because i have allready changed form a 305 to a 350.
Old Mar 7, 2003 | 09:03 PM
vwdave's Avatar
ESC module? *Feels dumb.*
I got the knock sensor though.
Old Mar 8, 2003 | 05:59 AM
jlbolin's Avatar
knock sensor Gm Part # is 10456288
ESC module # is 16128261
im not sure on price of knock but i know that the module is 41.96
goto www.gmpartsdirect.comthats where i got the # and prices.
Old Mar 8, 2003 | 11:50 AM
Car: 89 Camaro RS
Engine: 355 TBI
You can get them at autozone too. that's where i got mine
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
355tpipickup
Aug 19, 2015 10:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
