Yet another bogging/hesitation question
Old Mar 15, 2003 | 10:48 PM
cochev's Avatar
Car: 86 z28
Engine: 305 Carbed
ok, 90 burb, 350, tbi, high miles
have done the fallowing, new plugs, wires, cap and rotor, fuel filter, CTS tested bad so it was replaced, o2 sensor replaced, TPS tests ok, i only get 15" of vac but i can't find a leak anywhere.
the rig bogs off idle then picks up and takes off like a raped ape. if i start out slow it starts of ok for a bit then starts to bog, then cleans out and goes fine. obviously on grades, under a load the bogging is worse and it usually downshifts.
a lot of the search results i get on here say that bogging is most likely a fuel problem. could the pump be going bad even though it runs out great past the bogging? if it was carberated i'd say the accelerator pump was bad or out of adj.
Old Mar 16, 2003 | 11:29 AM
cochev's Avatar
Car: 86 z28
Engine: 305 Carbed
ok, feeling a bit retarded now. plugged off the egr and that got rid of 95% of the problem.
will running with this plugged for a while draw any codes?
Old Mar 16, 2003 | 01:25 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I think it will throw a code 43. theres a tech article on egr, it's function, and the code you will draw
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
